Does anyone know how to read the cause of the EML coming on. It seems to only do it on warm days & if I stop the engine & immediately restart it, it resets & stays off, makes me think the trigger may just be a momentary fault but that the light latches on until the engine is powered off.
It was an infrequent event but now happens on most longish journeys. There is no apparent loss of power or anything else noticeable. If you google it - it can mean a number of things. Just wondering if anyone else has experienced same & thereby work out which on the list of possibles I should try first. [I am thinking dirty mass airflow sensor] Thanks
Mine was in need of a replacement Fuel Oxygen sensor, the front one in the exhaust manifold. If you have an OBD reader it might help, my code was a P0171 system too lean (Bank 1). It would drive for a while with no light and then come on. There was a distinct smell of petrol from the exhaust.
Thanks Paul, that's useful & presumably means it using excess fuel in that condition. I've borrowed a basic OBD & will give it a try. Mine runs on LPG most of the time once started on petrol but I'll also check the exhaust when the light is on.
The OBD tool will need to support JOBD as its a version that looks to be specific to Japan, so don't be surprised if you don't get any readings from it. There is at least one post talking about compatible OBD tools, so could well be worth finding that.
Oh and yes it was using more fuel as the engine thought it was running lean and kept on putting more fuel in the mix. Anyway I cleaned the MAF, which made no difference, and then replaced the sensor, which was a pain as the previous person had broken the thread and I had to get a new tap and die (M18 x1.5) to cut the thread out again.
Edited by Gamith
To add bit about fuel and sensor.
Paul, thanks for your help - You were right the basic Foxwell OBD tool i used showed no error codes.
The EML is only getting more frequent though so Im going to start with (your) bank 1 lambda sensor.
I see they are available from AutoJap - My question now is, are they just plug & play or will I need someone to set it up/recode the management system?
Cheers
When I plugged my replacement it it just worked so I would imagine yours will be the same.
Cool, thanks ill give it a go.
Thanks again, Paul. I changed the bank 1 lambda sensor, no probs with new error codes or running issues. Unfortunately though, it hasn't stopped the EML coming on, so ill have to move on down the list of possible causes. I haven't been able to obtain the error code yet.
The issue, i would say is clearly linked to ambient temperature because on a warm day, as soon as you put the engine under a bit more than normal load (maintaining speed going up an incline), the light is triggered. doesn't seem to happen on cooler days. Still doesn't seem to affect running/power & always resets on shutdown/start-up.
The OBD should let you clear old codes, so I assume you have done that.
Hi guys,
I'm new to the world of the Alphard. My partner & I purchased ours back in June of this year - love it!
We too are having the exact issue described by Alphie though:
I've had it diagnosed at two different garages, replaced the Bank 1 Lambda Sensor - EML still coming on.
I'm now going to try and clean the MAF sensor and see if I can get any joy from that.
Wondering if many other people have had this fault and what other possible fixes I can try?
Thanks so much in advance for any help!!!
1 hour ago, Arran said:
Hi guys,
Hello Arran,
There is a second lambda sensor further down the exhaust - best to have the car on ramps for that, so it could be that, though I would expect a code to indicate the issue.
Other things to check are the air filter, MAF, coolant levels and, just in case, the battery connections.
As the temps are warmer get a JOBD compatible scanner (check the forums for suggestions), read, note down and then clear any existing codes, go for a drive - at least 10 mins to get it warmed up and when the EML lights up try the scanner again.
I'm sure others will be along with suggestions but if temperatures are the key then this time of year gives plenty of testing opportunities.
Thanks guys.
I’ve just cleaned the MAF sensor. It was dirty, understandable for an older vehicle I guess. It’s nice and clean now so fingers crossed that’s the end of our  issues :)
If the light comes on, when you stop check for codes before turning the engine off.
