I have a situation currently where only the drivers door window will open & close, (either in stages if required or automatically from fully open or closed). The other 3 will not open at all no matter what position the small square auto/manual switch is in.
I seem to remember a post some months ago regarding a similar issue.
Do the guru’s have advice?
This happens after the battery is reconnected.
From the drivers seat lower the window and hold the button down once it has reached the bottom for 10 seconds, then push the button up and hold for 10 seconds when it reaches the top.
Move to each window in turn and repeat.
That is assuming that the fuses are all Ok and, as you say, the window control isolation switch is not active.
Brilliant, I had lost total electrical power somehow due to a stuck starter solenoid.
No battery disconnects done.
I’m just back in after another play around & I think I’ve inadvertently followed your advice by going round all with ignition on & off.
Eureka! All is well
Thanks for the very swift advice!
