Door handle button not working
Hi everyone I’ve just joined this forum and Im just wondering if anyone had any info on why the door button on my Toyota doesn’t work is there a fuse or box of some sort that I need to change ,the key works fine
5 hours ago, Brandon said:
Hi everyone I’ve just joined this forum and I'm just wondering if anyone had any info on why the door button on my Toyota doesn’t work is there a fuse or box of some sort that I need to change ,the key works fine
Hello Brandon,
Which door ?
Do you have smart locking ?
If so, the button is a sensor not a push button.
Hi it’s on the drivers door and the rear tailgate just to double check I think I have the smart key is it the one with all the buttons on it which also opens the side electric doors
No. It does not operate the side doors.
The smart fob I have, for the same year as your model, is rectangular.
Has three buttons, lock and unlock, and tailgate.
On the back it has SMART DOOR LOCK. Capitals as per on the fob.
But it is much smarter than that. The van can sense it when near and unlock the vehicle as you approach (including the side doors).
If you walk away from the van with the fob in your pocket, the van will lock.
I also think you cannot lock the unit in the van.
It probably does a lot more, but those are the only features I am aware of.
The immobiliser key should open close the sliding doors, if the dash switch is enabled.
My immobiliser key has four buttons, Lock, unlock, and each power door.
Good Luck.
Hi so I take it that I don’t have a smart key fob, I have a key fob which unlocks the car by pushing the buttons on it .
so do you have 2 fobs one that starts the car with the key type fob and the other is a different fob which links to the black button on the door handle
Yes, I have three sets of keys.
Each set is a triangular immobiliser key, and the rectangular Smart key fob.
Hi many thanks for getting back to me again so I don’t have anything like that so I would need to buy the smart key fob and get it reprogrammed to my car
Hi there!
Perhaps a picture of the one you do have would help?
To avoid any confusion in description.
Cheers, Nev
This is the immobiliser key, and should open the side doors after you have unlocked the van.
I don't have a part number for the remote, or know where to get one programmed / matched to the van.
Maybe an auto-electrician can do it, maybe not.
Maybe a Toyota dealer, but that won't be cheap.
Make sure you have a spare immobiliser key.
Without one you cannot start the van, even with the remote.
This is the only key I have but the question is do I need to buy a smart key fob and get it programmed so that I can just push the black button on the drivers door to unlock or lock the car , the key that I have got in the picture works fine and I have 2 more of these exact same keys. I would just love to know how to use the black button on the drivers door
thanks again
Hi my vin no is ANH10-0145386 many thanks
thanks again
Pushing the black button does nothing !
You either need a remote as highlighted by Lee, or maybe some other issue is present.
My guess ?
You need the remote.
Hi many thanks for the info can can I ask can I buy a fob from alliexpress like this one in the picture or is this completely wrong
I cannot comment on whether this will work.
It looks nothing like the OEM unit, which has the Toyota trade mark moulded in.
I doubt any, other than a genuine Toyota unit will work straight from the box.
Maybe the Toyota one will need specialist programming, I don't know.
Many thanks for letting me know it looks like I might have to bite the bullet
and buy the proper one and hopefully it works and I haven’t got another problem with the keyless control unit which I’ve seen on eBay going for about £150 and then get it all reprogrammed
Hi Guys have just bought it on eBay will let you know how it goes and many thanks for all your help
Hi can you also tell me what this is for as it came with the car
Looks like a remote starter.
I believe it is illegal to start a vehicle remotely in the UK if vehicle is on a public road.
