Hello - New member having just bought a newly imported 2010 350 - Apologies if this is an existing thread, but can anyone tell me how to stop the mirrors folding every time I lock the vehicle? Have looked online but to no avail.
If you get an OBD reader, you can get the free Carscanner app. This will let you alter this and other setting like being able to close and open windows on the remote, light sensetivity. I bought a Veepeak OBDCheck BLE OBD2 and it works great
Hi Malcolm!
My guess is you are going to love it!
I can highly recommend the "JPNZ" owners manuals!
I actually bought one before we had the car, we were fairly sure that we were having one!
They are not a workshop manual, but they give lots of bits of useful information how little functions work, that may take a lot of figuring out otherwise.
I did also download an owners manual a member very kindly put on the forum, about May this year I think, (can't find it right now) and got my local little print shop to print it out for me. It's 550 pages, but they printed it 2 to an A4 sheet and double sided.
I may be a little sad, but it's interesting reading. I am that man who reads the manual whenever we got a "new" car 🤣
But anyway - your question - below the START button is a rectangular switch with AUTO on it and 2 pictures of the mirrors, top one out, bottom one in. On mine in the middle position it will fold / unfold on locking / unlocking. If you press it in at the top, they will stay out, at least they do on mine!
Cheers, Nev
Edited by BigNev
Yes JPNZ worth the investment.
On my earlier model there is a switch to stop mirrors folding .
Are you sure you don't have one too ?
Thank you very much to everyone for taking the time to respond. There is no button on my car that I can find that stops the mirrors folding in - I bought the car from an importer who has quite a few of these vehicles in stock and they did identify this button on other models in different dashboard locations, including one exactly where Neville said it would be, but on my car there is no such button or at least I can't find it and neither can the importer.
I know that on some other Toyota models there is a function whereby you press and hold down the mirror fold button while pressing one of the arrows on the mirror position control button and this disables the automatic fold but I have tried this and it does not work.
I do know a couple of Japanese people who I see occasionally and my current plan is to take the original Japanese owner's handbook when I next see them and pester them to figure it out.
I am sure that getting an OBD reader is a good idea (thank you Craig) - I normally work on much older cars where they are not required, but I think on this vehicle it would be very wise to have one, I will look into the JPNZ manuals.
Well blooming heck!
You live and learn!
Let us know the technique if you get it sorted please!
Cheers, Nev
Edited by BigNev
What switch is fitted in the position where the folding mirror switch should be?
Please post photo of the switches either side of the steering wheel.
It's possible, a previous owner in Japan moved the physical switch behind the dash panel in order to free up the slot for something else.
The fact your mirrors appear to have motors means there should be the wiring and therefore the switch in place.
There are 3 mirror types.
One is completely manual ( only has control for adjusting glass)
One has fold and unfold via motor and a rocker switch.
One has motor and rocker switch with an additional auto position.
It's possible you have the second option, and an aftermarket module that uses the central locking signal to logic switch between the open/close states.
To determine if you have the 2nd or 3rd option, check if you have auto tilt mirrors.
With vehicle in reverse gear, flip the mirror adjust button ( the left right toggle between the center neutral position and either left or right.
In the center position the mirror should be as normal, when moved to the left or right, the mirror will automatically adjust so the mirror tilt down to show the road.
Switch should look like this.
You can also auto tilt the mirrors when you select reverse if you keep the left/right rocker switch on the door to one side or the other.
Ah ECO mode button, I wish I had it!!
Sorry, off thread!
Hello again
As requested, the pictures are attached below, the toggle switch below the start button is the rear fog light installed by the importer.
As regards the tilting mirrors - On my car, only the left hand side passenger side mirror tilts downwards when reverse is selected and it does this regardless of which position the L-R mirror adjustment switch is in. The little button in the door mounted controls that shows the mirrors folding will only fold the mirrors in when the ignition is on - It does not affect them folding in automatically when locking the car, which is what I was trying to prevent.
Thanks again for the help.
P1010389.thumb.JPG.4fe857734bdd8c590c06833b7f27d239.JPGP1010390.thumb.JPG.5075880a2805ce71a16c8e1c89c51f45.JPG
Ah, chuffing heck.
My mistake, should have asked for a picture first, as one paints a thousand words!
Hi everyone, this is my first post I bought a 2009 Vellfire 3.5l last week.
Exact same setup as Malcolm with no mirror switches under the start engine button and just a folding mirror button on the drivers armrest.
But I have the opposite problem, the only way to fold the mirrors is to press the button.
I would love to know how to get the mirrors to automatically fold when i lock the doors.
Also neither of my mirrors angle down when in reverse, doesn't matter if switch is set to left, right or centre.
Any advice how I can fix these 2 issues?
Also, I don't have a button for ECO but the ECO light keeps turning on on the Speedo instrument cluster whenever I'm not accelerating
I believe the folding when locking is an aftermarket module they may have installed (previous owner).
You can buy these modules on AliExpress.
The auto tilt mirrors are not installed on every model, you appear to have a base level vehicle.
The auto tilt requires the mirror that has the additional motor wiring and hall effect sensors, often combined with the electrically adjustable drivers seat and seat memory ecu.
If your driver's seat is manually adjustable rather than using buttons, you will not have auto tilt mirrors or auto folding.
The fold mechanism is just holding the signal at ground, which is what an aftermarket module will do in combination with the central locking signal.
You can also use the button on the steering wheel to select the eco display on the dash, so you can see how hard you are accelerating.
The eco button is really just the opposite of a 'sports' button that some Toyota have, it just softens the accelerator response.
I turned off the eco light as it was distracting flashing on and off.
Thankyou so much for all the info Chris.
Still having a hard time getting my mirrors to fold when locking like Malcolm's does.
I bought an aftermarket module from AliExpress, which was supposed to fix the mirror fold, allow windows to be operated by key fob and stop the car from unlocking the doors everytime I put her in park.
The device did none of the above but now when ever I start the car it beeps twice and does this 5 consecutive times and stops (no error lights on dash or anything) 😭.
I returned the module and purchased a veepeak obd Bluetooth from amazon as suggested in the post above.
Hoped it would allow my mirrors to fold when locking and find a fault code that's causing the beeps.
Just received today, there is an option to allow windows to open and close by the key fob which I tested and works perfectly.
But still no option to auto fold mirrors or to stop the car from unlocking doors when put into park, the JPNZ manual does list this as an option though but maybe I'm using the wrong connection profile (I'll post a pic below this post).
Ran the fault code test to find out the source of the beeping caused by the AliExpress module and got heaps of codes (pics below).
Cleared the codes and reran the test, this time only 3 codes came up relating to the parking sensors, beeping still continues on start up. I'm still yet to take her for a drive yet to see if any other fault codes come back.
Hi John!
IF yours is the same as mine, and that ECO word lighting up is on the bottom right of the rev counter, it's just an indicator to say you're driving economically, according to my manual.
Cheers, Nev
Edited by BigNev
