I need sensible suggestions
My v6 Alphard A10 has a body vibration between 40_70 mph which is not felt in the steering.? the garage says nothing obvious loos or falling off or worn. they are not confident it is drive shafts.it is now making it difficult to drive at spped. Help??
I read you say not tyre balance, but have YOU had the rears double checked?
As it is not being felt via the steering, then the problem has to be at the rear, so the most obvious would be wheel balance or worn rear axle bushes or wheel bearing or buckled wheel
