The Brand Your Toyota Has Known Longer Than You Have
How ENEOS, Japan's number one motor oil, finally arrived on British shores — and why it matters to every driver in this club.
There's something quietly satisfying about owning a Toyota or a Lexus. It's not about shouting from the rooftops. It's about knowing — really knowing — that what sits on your driveway was built properly, engineered with obsessive care, and designed to last. Whether it's a humble Yaris that has clocked 200,000 miles without so much as a hiccup, a GR86 that makes every B-road feel like a racetrack, or a silken Lexus LS that still whispers its way down the motorway after a decade of faithful service, these are cars built around a philosophy: do it right, or don't do it at all.
15% club discount using code OIL15
So it's always struck me as odd — and frankly a little disrespectful — that so many of us in the UK have been pouring oil into these Japanese masterpieces that has absolutely nothing to do with Japan. We trust Shell, Castrol, Mobil. They're fine brands. But ask yourself honestly: did those companies help engineer your Toyota's engine? Did they sit alongside Toyota's own R&D teams in Tokyo, refining base oils and additive packages specifically for the GR engines, the D-4ST injection systems, the 2GR-FKS V6, the M20A-FXS hybrid unit? Because there is an oil company that did exactly that.
Its name is ENEOS and it's been Japan's number one motor oil for over a hundred thirty five years!
Most UK drivers have never heard of ENEOS, which is entirely understandable — it simply wasn't available here. But in Japan, ENEOS is as familiar as Castrol is to a British motorist. It is the premium lubricant brand of ENEOS Corporation, Japan's largest oil company, with roots stretching back to 1888 — yes, 1888 — when it was founded as Nippon Oil. It has spent well over a century developing lubricants at the very highest level, and today supplies factory fill and genuine OEM oils to the major Japanese automakers, including Toyota and Lexus themselves.
That point is worth dwelling on. When a brand new Toyota or Lexus rolls off the production line in Japan and is filled with oil for the very first time, there is a very strong possibility that oil carries the ENEOS name. Not because it was the cheapest option. Not because of a marketing deal. But because ENEOS engineers worked directly with Toyota's engineers to develop lubricants that meet and exceed the precise tolerances of those engines. It is a collaborative relationship built over decades, and the result is an oil formulated from the inside out — starting with what the engine actually needs, not what the marketing department wants to say about it.
Finally Available in the UK — Through R5 Lubricants
Until recently, if you lived in the UK and wanted ENEOS oil, you were out of luck. The brand had strong distribution across Europe and across Asia, but this island somehow got overlooked. That changed when R5 Lubricants www.r5lubricants.com specialist UK lubricant company based in Bradford, West Yorkshire became the official UK distributor for ENEOS Oil. It was an announcement welcomed by Japanese car enthusiasts up and down the country and rightly so.
R5 Lubricants are not a faceless multinational. They are a focused, enthusiast-driven business that understood exactly what the UK Japanese car community had been missing, and they set about putting it right. Based at Ripley Road Business Park in Bradford, they stock the full ENEOS range — passenger car engine oils, motorbike oils, transmission fluids and brake fluids — and they ship nationwide.
What sets R5 apart is that they actually understand the products they sell. When ENEOS says a particular oil is engineered specifically for Toyota and Lexus hybrid powertrains, the team at R5 can tell you exactly which specification you need, for which engine and why. That kind of knowledge matters when you're looking after a car you care about.
Why Japanese Oil for a Japanese Engine Makes Perfect Sense
Before we get into the specific products, let's address the most obvious question: does it actually make a difference which oil you use, as long as it meets the correct specification?
In a perfect world, probably not. In the real world, yes — and here's why.
Modern engines are extraordinarily precise machines. The tolerances inside a Toyota GR engine or a Lexus V8 are measured in microns. The oil does not simply lubricate; it actively participates in the engine's operation. It manages heat, cleans internal components, maintains hydraulic pressure for the variable valve timing systems and in hybrid vehicles, it works alongside an electric powertrain in ways that create unique thermal and chemical demands that simply did not exist twenty years ago.
ENEOS understands those demands at a fundamental level, because ENEOS engineers helped design around them. Their formulations for Toyota and Lexus vehicles are not adaptations of existing products — they are purpose-built solutions, developed through joint research programmes, tested under conditions that replicate real-world Toyota and Lexus operation. When ENEOS specifies an oil for your IS250, your Prius, your GR Yaris or your Lexus NX 450h+, that specification came from the inside.
The Products Every Toyota and Lexus Owner Should Know
ENEOS X 0W-16 Ultra is the headline product for hybrid and plug-in hybrid owners and if you're running a Lexus ES 300h, UX 300h, NX 450h+, or any Toyota hybrid from the Yaris upwards, this is the oil that was engineered specifically for your engine.
Ultra-low viscosity 0W-16 is now specified by Toyota as factory fill in Japan, and for good reason — it dramatically reduces internal friction, which directly translates to better fuel economy and lower emissions. ENEOS X 0W-16 Ultra carries **API SP, SN Plus Resource Conserving, and ILSAC GF-6B** certification, and it is specifically engineered with **LSPI (Low-Speed Pre-Ignition) protection** — a critical safeguard for turbocharged direct-injection engines that, when it goes wrong, can be catastrophic and expensive. For hybrid owners, this is not a "premium upgrade." It is the correct oil for your engine, full stop.
ENEOS X 0W-20 Ultra covers the broader Toyota and Lexus range — naturally aspirated petrol engines, hybrids, PHEVs and even range-extender battery electric vehicles. Holding **API SP/RC and ILSAC GF-6A** certification, it is recommended directly by ENEOS for gasoline and hybrid engines from Toyota and Lexus across their current range. It delivers outstanding protection against deposits, superb cold-start performance — which matters enormously for hybrid engines that frequently shut down and restart — and measurable improvements in fuel economy compared to conventional synthetics of the same viscosity grade.
ENEOS Hyper-Multi 5W-30 rounds off the core passenger car range for those with older Toyota and Lexus models requiring a broader mid-weight specification. Fully synthetic, engineered to ACEA standards, and benefiting from ENEOS Corporation's advanced additive technology, it is a product that punches well above its weight in terms of engine cleanliness and wear protection.
Motorsport Credentials — Earned, Not Bought
For those of you who like to know the oil in your car has been tested rather further than a laboratory — ENEOS has a serious motorsport pedigree. The brand has backed Evasive Motorsports' Toyota 86 at the legendary Pikes Peak International Hillclimb, one of the most brutal environments an engine can face: altitude-induced air thinning, extreme temperature swings, and prolonged full-throttle running up a mountain. They have been deeply associated with the Toyota GR Supra in competition trim, and their oils are trusted by drivers who cannot afford for their engine to fail at any point on that hill.
For GR86, GR Yaris and GR Corolla owners in particular, this is worth knowing. The same technology that protects a race-prepared Toyota at 14,115 feet above sea level is inside every bottle that R5 Lubricants dispatches from Bradford!
The Japanese Philosophy That Connects It All
There is a concept in Japanese culture called "monozukuri" — a Japanese philosophy and practice of manufacturing that combines technical, high-quality production with a deep, spiritual dedication to craftsmanship, continuous improvement (kaizen), and a pursuit of perfection.
It is not simply manufacturing; it is a commitment to craftsmanship, to continuous improvement, to the idea that every product, no matter how small, deserves to be made with genuine care and thought. It is the reason your Toyota or Lexus starts reliably on a November morning after three weeks sitting on the drive. It is the reason these cars hold their value, survive high mileages and generate the kind of fierce loyalty you see on forums like this one.
ENEOS carries the same philosophy. It is not a company that produces lubricants to a minimum acceptable standard. It is a company that has spent 135+ years asking what more an oil can do, how it can be refined further, how it can better serve the engines it protects. That shared DNA — ENEOS and Toyota, both born in Japan, both shaped by the same national commitment to engineering excellence — is not a marketing story. It is a straightforward fact.
When you choose ENEOS oil through R5 Lubricants, you are not simply buying engine oil. You are completing the circle. You are giving your Japanese-engineered car the Japanese-engineered oil that was developed alongside it.
Where to Buy
R5 Lubricants Ltd - https://r5lubricants.com — Official UK Distributors for ENEOS
📍 Unit 1 Ripley Road Business Park, Bradford, West Yorkshire, BD4 7EX
📞 0113 532 3355
📧 [email protected]
🌐 www.r5lubricants.com
Use the Oil Selector on the R5 Lubricants website — simply enter your registration (VRM) or select your make and model and it will show you precisely which ENEOS oil is correct for your vehicle.
Standard UK delivery is available nationwide, with a 14-day returns policy on all orders.
A Final Word
There will always be people in this hobby who say oil is oil, that any fully synthetic meeting the right API rating will do and that spending more than necessary is just falling for marketing. I respect that view — it is not entirely wrong.
The engineering standards required for a lubricant to carry an API SP or ILSAC GF-6B certification are genuinely high and most reputable brands meet them.
But some of us want something more than "meeting the minimum." Some of us chose a Toyota or a Lexus precisely because we don't believe in doing things by halves. We bought a car over-engineered for its class because we understand that quality has a long-term payoff. Looking after it with the oil that helped engineer those engines is simply the natural extension of that decision.
ENEOS is now in the UK with R5 Lubricants…it’s available, competitively priced and ready to earn your trust.
Give it a try — your engine already knows the brand.
15% discount using code OIL15
*Article supplied on behalf of [R5 Lubricants Ltd](https://r5lubricants.com), official UK distributors for ENEOS motor oil.*
I tried the vehicle selector and it doesn't seem to know about Alphards. I tried my number plate as well as searching by make - no model matched though. The Previa looks to be the closest, or maybe the avensis.
I did a Ai search and checked my previous grade and was correct. PLEASE CHECK YOURSELF FIRST or speak with Paul or Steve At R5lubricants
15% off code OIL15
🚐 1st Generation (AH10) – 2002–2008
ANH10W / ANH15W
Engine: 2.4L 2AZ-FE
Oil Grade:
  • ✅ 5W-30 (most common)
  • 10W-30 (acceptable in warmer climates)
ATH10W (Hybrid)
Engine: 2.4L 2AZ-FXE Hybrid
Oil Grade:
  • ✅ 5W-30
  • 0W-20 (acceptable in colder climates)
MNH10W / MNH15W
Engine: 3.0L 1MZ-FE V6
Oil Grade:
  • ✅ 5W-30
  • 10W-30 (warm climate alternative)
🚐 2nd Generation (AH20) – 2008–2014
ANH20W / ANH25W
Engine: 2.4L 2AZ-FE
Oil Grade:
  • ✅ 0W-20 (preferred for fuel economy)
  • 5W-30 (acceptable alternative)
ATH20W / DAA-ATH20W (Hybrid)
Oil Grade:
  • ✅ 0W-20 (preferred)
  • 5W-30 (acceptable)
GGH20W / GGH25W
Engine: 3.5L 2GR-FE V6
Oil Grade:
  • ✅ 5W-30
  • 0W-20 (some later models allow)
🚐 3rd Generation (AH30) – 2015–2018
AGH30W / AGH35W / AGH40W / AGH45W
Engine: 2.5L 2AR-FE
Oil Grade:
  • ✅ 0W-20 (primary Toyota spec)
  • 5W-30 (backup option)
AYH30W / DAA-AYH30W (Hybrid)
Engine: 2.5L 2AR-FXE Hybrid
Oil Grade:
  • ✅ 0W-20 (strongly recommended)
GGH30W / GGH35W
Oil Grade:
  • ✅ 5W-30
  • 0W-20 (some facelift models allow)
