Back box
Does anybody know where I can get a new or used back box for my alphard
Might be worth checking amayama.com as a back box for mine looks to be a lot less than that:
Strangely the same part number looks to have two different designs, so definitely worth checking.
There are some 17430 20090 items on ebay.co.uk which may be worth a look, though again a thorough check would be advised :-)
good luck
ebay will most likely have some 2nd hand boxes, for the price of a box from Toyota you could get a cat back stainless steel system
good luck
The difference in your screen shot on the back box model no. Top exhaust is anh10 bottom exhaust anh15 anh10 2wd and anh15 4wd
Thanks for the explanation - makes sense as it would have to go over a drive shaft. Obviously the pictures aren't that model-specific :-)
