Yaw/Acceleration Sensor
I would like to hear from anyone whose E-four Alphard randomly changes from 100% front axle drive to engage the rear axle causing an audible clunk (often heard when accelerating from a standing start). My Alphard has always made a rear axle clunk when first accelerating. I have read this was a common criticism of 1st generation hybrids.
This sounds more like play in the rear drive shafts CV joints or the drive motor assy itself, as there is nothing random in the E-Four system deciding when to drive the rear motor.
From the manual:
Start control.
The system calculates the total drive torque for the front and rear wheels from the accelerator request drive torque and shift position signal input from the HV control computer, calculates the optimal front and rear drive torque distribution for slippery roads taking into account the front and rear wheel weight distribution, and outputs the calculation result to the HV control computer. This control ensures excellent starting performance on slippery roads.
Normal Control.
The system calculates the optimal front/rear drive force distribution based on the accelerator request drive torque, shift position signal, wheel speed, steering angle, etc. input from the HV control computer, and outputs a front/rear drive torque distribution signal to the HV control computer to ensure vehicle stability. To excellent fuel efficiency, the rear-wheel drive motor generator is basically inactive and the vehicle runs in front-wheel drive. On slippery roads, the system optimally distributes front/rear drive torque when accelerating, steering, or making tight turns such as U-turns.
Thanks for your reply Jeza. Well I was way off with my suspicions. I have been told the fault code causing all my warning lights says it is my inverter - Toyota Assy G9200-58010 RA28W006. A replacement, even second hand, is priced around $4500 USD. Maybe I can find someone in Perth Australia able to do a repair .... If anyone has had this issue themselves, comments would be welcome.
I am posting a photo of my dashboard warning lights again, plus the fault codes that were associated with them - for anyone else who may get this problem. The car started normally, but fault lights appeared when the car was put into R or D. Driving is possible, but you may go into "Limp" mode. (And all of the strange noises come from the rear axle!)
P3125 Inverter fault
C1259 HV system fault regenerative
C1310 HV system fault
2008 ATH10W.pdf
From what I've read (ie no experience myself) the 10 series inverters tend to die because the IGBTs inside overheat and tend to cook themselves, which can be made worse by failing coolant pumps or lack of coolant changes. I'm not familiar enough with the codes to confirm if that's the case for yours. You can find videos of burnt out Prius inverter IGBTs to see what happens.
I think the IGBTs inside are in theory replaceable, but Toyota no longer has them so you'd need to get some from a scrapped inverter. Or maybe there are alternatives that can be used (awkward, as they need to be in thermal contact with the cooling plate).
I would look around locally for any hybrid specialists: if you have eg Prius taxis then they should exist, but you need someone with more electrical skill than just swapping modules.
The problem with the P3125 inverter fault code is that there is around 100 sub codes in the form of P3125-xxx. The sub code identifies which component, wiring, monitoring system is at fault. If you can get the full fault code read it will help you, Techstream will do this plus other JOBD readers might. C1259 and C1310 come on with a hybrid fault, as regenerative braking is no longer possible and the rear motor isolated, which is used for stability control, hence the VSC light.
If there is a fault detected by the Skid Control Computer it will communicate this to the Hybrid Control Computer which will light the "red car !" and isolate the hybrid system from the skid control system. The same happens if the HV battery computer detects a fault or potential issue like a block abnormality.
