Bulb List for Gen 1
Dashboard/console led/bulb = t4.7 for the backlight of the clock etc and t3.5 for the buttons
Buttons either side of steering wheel = T3
Headlights - Halogen Headlights = H4 60/55W
Discharge Headlights
 - High Beam = HB3 60W
- Low Beam = Not fitted with intelligent AFS = D2R 35W
                         Fitted with AFS = D2S 35W
Front Fog Light = HB4 51W
 -mz * mx * ax = 55W
 - MS * AS = 35w
Clearance Lights = W5W 5W
Front Indicator/Hazard Lights = 1W
Side indicator/hazard = W5 12V
Number Plate = W5W 93R
Brake Lights = 21W
Tail Light = 2DIW SW7443 21w
 Rear Indicators = 2FH 21W
Reverse Light = W6W 21W
Rear Fog Light = 21W optional change to the reflectors HERE
Front Personal Light = 8W
Rear Personal Light = 5W
Vanity Light = 1.5W
Front Door Courtesy Light = 3.8W
Foot Area (not present cant tell you) =
Luggage room light = 5W
Ashtray = 1.2W
High mount stop light =W16W 16W
Bulb List for Gen 2.
Here's a general list of common bulb types. It's highly recommended to double-check your vehicle's owner's manual or visually inspect the bulbs in your specific Alphard before purchasing replacements.
Headlights:
  • Low Beam:
    • Halogen: H1, H7, H11, HIR2
    • Xenon/HID: D2S, D4S (These are usually for vehicles with factory HID systems. Note the voltage difference - 85V for D2S/D4S vs. 12V for halogen.)
  • High Beam:
    • Halogen: H4 (often combined with low beam in one bulb for some models), HB3 (9005)
  • Fog Lights: H8, H11, H16 (H11 is very common)
Exterior Lighting (other):
  • Front Turn Signals: WY21W (amber) or 7440/7440A (some models might use W21W with an amber lens)
  • Front Side Marker/Position Lights: W5W (T10 wedge)
  • Rear Turn Signals: WY21W or W21W (if the lens is amber)
  • Brake/Tail Lights: W21/5W (dual filament for brake and tail), P21/5W, P21/4W, R10W (some models may have LED tail lights, which would be integrated units)
  • Reverse Lights: W16W, P21W
  • License Plate Lights: W5W (T10 wedge)
Interior Lighting:
  • Dome Lights / Map Lights / Reading Lights: Typically use a variety of bulbs, including:
    • Festoon bulbs (various lengths like 31mm, 36mm, 39mm, 41mm)
    • W5W (T10 wedge)
    • Some areas might use smaller wedge bulbs like T5.
  • Vanity Mirror Lights: Often smaller festoon or W5W bulbs.
  • Trunk/Boot Light: W5W or a festoon bulb.
  • Door Lights: W5W
  • 9 months later...
You could make a small fortune selling sets of these.   Or just outside light sets.
  • 3 months later...
Hi
I've got a Gen2 would you help with the bulb list please.
many thanks in advance.
  • 3 months later...
On 6/19/2022 at 7:36 AM, MonsterS said:
Bulb List for Gen 1
 -mz * mx * ax = 55W
 - MS * AS = 35w
Brake Lights = 21W
Vanity Light = 1.5W
Ashtray = 1.2W
If you have a Gen 2 please message me and I will update the list.  If i'm missing any them let me know too. Thank you
Do these bulbs use CANBUS, if switching to LED (specifically the fog lights and all headlight bulbs?) ..or better to buy non-CANBUS LED bulbs?
Nope, however if converted to LED it will fail forexternal headlights please see from gov.uk
"Section 4.1.4 of the current MOT inspection manuals for both motorcycles and cars and passenger vehicles states ‘Existing halogen headlamp units should not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp.’"
Reference https://www.gov.uk/government/publications/special-notice-01-21-headlamp-conversions/mot-special-notice-01-21-headlamp-conversions
Haha, I'm not concerned about failing any sort of future inspections, as here in Canada things are a bit different.
  • 7 months later...
I was going to fit switchback DRL's in place of the indicators. From deciphering The manual and looking for equivalents, can anyone confirm that the indicator bulbs are PY21W fitting? The switchback ones come with several plug and play connections, you have to choose the fit.
Ok, cars back home and so went and checked : WY21W,  which I think equates to T20.
I've just bought a gen 1 and the passenger side front personal light is out. I ordered a replacement bulb but it's still not working. Have I ordered the wrong bulb or could there be a problem with the fixing itself?
https://www.ebay.co.uk/itm/363513048214
Hello Alistair,
Welcome to the Forum
  • 3 months later...
Just found this post and saw
 Just for an update, this has been changed to this;
Existing halogen headlamp units on vehicles first used on or after 1 April 1986 must not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp for light source and lamp not compatible.
Reference https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/4-lamps-reflectors-and-electrical-equipment#section-4-1-4
From my understanding from reading this, its ok to change to LED's now
I was wondering if anyone knows what type of bulb is used for the switches that light up on the centre console. The bulb for my A/C switch has gone on my 20 series. If anyone can point me in the right direction it would be a great help.
On 7/19/2023 at 7:26 PM, Cookie crew said:
Hi
Me too, just bought a 2009 and could do with a list. Thanks
Anyone know gen 1 hybrid tail light?
On 6/19/2022 at 3:36 PM, MonsterS said:
Bulb List for Gen 1
 -mz * mx * ax = 55W
 - MS * AS = 35w
Brake Lights = 21W
Vanity Light = 1.5W
Ashtray = 1.2W
The Gen 2 list would be great please.
Did you ever get to fix this, as I've got the same issue. Just going to investigate further as both bulbs are good. As an aside, has anyone found a UK source for the 8w bulbs used in the front personal light?
