MonsterS Posted June 19, 2022 Posted June 19, 2022 Bulb List for Gen 1 Dashboard/console led/bulb = t4.7 for the backlight of the clock etc and t3.5 for the buttons Buttons either side of steering wheel = T3 Headlights - Halogen Headlights = H4 60/55W Discharge Headlights - High Beam = HB3 60W - Low Beam = Not fitted with intelligent AFS = D2R 35W Fitted with AFS = D2S 35W Front Fog Light = HB4 51W -mz * mx * ax = 55W - MS * AS = 35w Clearance Lights = W5W 5W Front Indicator/Hazard Lights = 1W Side indicator/hazard = W5 12V Number Plate = W5W 93R Brake Lights = 21W Tail Light = 2DIW SW7443 21w Rear Indicators = 2FH 21W Reverse Light = W6W 21W Rear Fog Light = 21W optional change to the reflectors HERE Front Personal Light = 8W Rear Personal Light = 5W Vanity Light = 1.5W Front Door Courtesy Light = 3.8W Foot Area (not present cant tell you) = Luggage room light = 5W Ashtray = 1.2W High mount stop light =W16W 16W Bulb List for Gen 2. Here's a general list of common bulb types. It's highly recommended to double-check your vehicle's owner's manual or visually inspect the bulbs in your specific Alphard before purchasing replacements. Headlights: Low Beam: Halogen: H1, H7, H11, HIR2 Xenon/HID: D2S, D4S (These are usually for vehicles with factory HID systems. Note the voltage difference - 85V for D2S/D4S vs. 12V for halogen.) High Beam: Halogen: H4 (often combined with low beam in one bulb for some models), HB3 (9005) Fog Lights: H8, H11, H16 (H11 is very common) Exterior Lighting (other): Front Turn Signals: WY21W (amber) or 7440/7440A (some models might use W21W with an amber lens) Front Side Marker/Position Lights: W5W (T10 wedge) Rear Turn Signals: WY21W or W21W (if the lens is amber) Brake/Tail Lights: W21/5W (dual filament for brake and tail), P21/5W, P21/4W, R10W (some models may have LED tail lights, which would be integrated units) Reverse Lights: W16W, P21W License Plate Lights: W5W (T10 wedge) Interior Lighting: Dome Lights / Map Lights / Reading Lights: Typically use a variety of bulbs, including: Festoon bulbs (various lengths like 31mm, 36mm, 39mm, 41mm) W5W (T10 wedge) Some areas might use smaller wedge bulbs like T5. Vanity Mirror Lights: Often smaller festoon or W5W bulbs. Trunk/Boot Light: W5W or a festoon bulb. Door Lights: W5W 2 3
Tylersm90 Posted April 13, 2023 Posted April 13, 2023 You could make a small fortune selling sets of these. Or just outside light sets.
Cookie crew Posted July 19, 2023 Posted July 19, 2023 Hi I've got a Gen2 would you help with the bulb list please. many thanks in advance.
mattieewhooo Posted November 11, 2023 Posted November 11, 2023 On 6/19/2022 at 7:36 AM, MonsterS said: Bulb List for Gen 1 Dashboard/console led/bulb = t4.7 for the backlight of the clock etc and t3.5 for the buttons Buttons either side of steering wheel = T3 Headlights - Halogen Headlights = H4 60/55W Discharge Headlights - High Beam = HB3 60W - Low Beam = Not fitted with intelligent AFS = D2R 35W Fitted with AFS = D2S 35W Front Fog Light = HB4 51W -mz * mx * ax = 55W - MS * AS = 35w Clearance Lights = W5W 5W Front Indicator/Hazard Lights = 1W Side indicator/hazard = W5 12V Number Plate = W5W 93R Brake Lights = 21W Tail Light = 2DIW SW7443 21w Rear Indicators = 2FH 21W Reverse Light = W6W 21W Rear Fog Light = 21W optional change to the reflectors HERE Front Personal Light = 8W Rear Personal Light = 5W Vanity Light = 1.5W Front Door Courtesy Light = 3.8W Foot Area (not present cant tell you) = Luggage room light = 5W Ashtray = 1.2W High mount stop light =W16W 16W Bulb List for Gen 2. If you have a Gen 2 please message me and I will update the list. If i'm missing any them let me know too. Thank you Do these bulbs use CANBUS, if switching to LED (specifically the fog lights and all headlight bulbs?) ..or better to buy non-CANBUS LED bulbs?
MonsterS Posted November 11, 2023 Author Posted November 11, 2023 1 hour ago, mattieewhooo said: Do these bulbs use CANBUS, if switching to LED (specifically the fog lights and all headlight bulbs?) ..or better to buy non-CANBUS LED bulbs? Nope, however if converted to LED it will fail forexternal headlights please see from gov.uk "Section 4.1.4 of the current MOT inspection manuals for both motorcycles and cars and passenger vehicles states ‘Existing halogen headlamp units should not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp.’" Reference https://www.gov.uk/government/publications/special-notice-01-21-headlamp-conversions/mot-special-notice-01-21-headlamp-conversions 1
mattieewhooo Posted November 11, 2023 Posted November 11, 2023 Haha, I'm not concerned about failing any sort of future inspections, as here in Canada things are a bit different.
av02 Posted July 7, 2024 Posted July 7, 2024 I was going to fit switchback DRL's in place of the indicators. From deciphering The manual and looking for equivalents, can anyone confirm that the indicator bulbs are PY21W fitting? The switchback ones come with several plug and play connections, you have to choose the fit.
av02 Posted July 7, 2024 Posted July 7, 2024 Ok, cars back home and so went and checked : WY21W, which I think equates to T20.
allymonty Posted August 14, 2024 Posted August 14, 2024 I've just bought a gen 1 and the passenger side front personal light is out. I ordered a replacement bulb but it's still not working. Have I ordered the wrong bulb or could there be a problem with the fixing itself? https://www.ebay.co.uk/itm/363513048214
Rojie Posted August 14, 2024 Posted August 14, 2024 4 hours ago, allymonty said: I've just bought a gen 1 and the passenger side front personal light is out. I ordered a replacement bulb but it's still not working. Have I ordered the wrong bulb or could there be a problem with the fixing itself? https://www.ebay.co.uk/itm/363513048214 Hello Alistair, Welcome to the Forum
Voodoo101 Posted December 11, 2024 Posted December 11, 2024 Just found this post and saw On 11/11/2023 at 9:12 AM, MonsterS said: Nope, however if converted to LED it will fail forexternal headlights please see from gov.uk "Section 4.1.4 of the current MOT inspection manuals for both motorcycles and cars and passenger vehicles states ‘Existing halogen headlamp units should not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp.’" Reference https://www.gov.uk/government/publications/special-notice-01-21-headlamp-conversions/mot-special-notice-01-21-headlamp-conversions Just for an update, this has been changed to this; Existing halogen headlamp units on vehicles first used on or after 1 April 1986 must not be converted to be used with high intensity discharge (HID) or light emitting diode (LED) bulbs. If such a conversion has been done, you must fail the headlamp for light source and lamp not compatible. Reference https://www.gov.uk/guidance/mot-inspection-manual-for-private-passenger-and-light-commercial-vehicles/4-lamps-reflectors-and-electrical-equipment#section-4-1-4 From my understanding from reading this, its ok to change to LED's now
Jimmympv Posted January 4 Posted January 4 I was wondering if anyone knows what type of bulb is used for the switches that light up on the centre console. The bulb for my A/C switch has gone on my 20 series. If anyone can point me in the right direction it would be a great help.
JohnVNewcomb Posted April 1 Posted April 1 On 7/19/2023 at 7:26 PM, Cookie crew said: Hi I've got a Gen2 would you help with the bulb list please. many thanks in advance. Me too, just bought a 2009 and could do with a list. Thanks
Ian Preston Posted June 7 Posted June 7 On 6/19/2022 at 3:36 PM, MonsterS said: Bulb List for Gen 1 Dashboard/console led/bulb = t4.7 for the backlight of the clock etc and t3.5 for the buttons Buttons either side of steering wheel = T3 Headlights - Halogen Headlights = H4 60/55W Discharge Headlights - High Beam = HB3 60W - Low Beam = Not fitted with intelligent AFS = D2R 35W Fitted with AFS = D2S 35W Front Fog Light = HB4 51W -mz * mx * ax = 55W - MS * AS = 35w Clearance Lights = W5W 5W Front Indicator/Hazard Lights = 1W Side indicator/hazard = W5 12V Number Plate = W5W 93R Brake Lights = 21W Tail Light = 2DIW SW7443 21w Rear Indicators = 2FH 21W Reverse Light = W6W 21W Rear Fog Light = 21W optional change to the reflectors HERE Front Personal Light = 8W Rear Personal Light = 5W Vanity Light = 1.5W Front Door Courtesy Light = 3.8W Foot Area (not present cant tell you) = Luggage room light = 5W Ashtray = 1.2W High mount stop light =W16W 16W Bulb List for Gen 2. If you have a Gen 2 please message me and I will update the list. If i'm missing any them let me know too. Thank you The Gen 2 list would be great please.
MonsterS Posted June 9 Author Posted June 9 @Ian PrestonI've pm'd you and added what I know to it. I do not have a gen 2 so it might be slightly off.
Hillclimber Posted Tuesday at 09:15 AM Posted Tuesday at 09:15 AM On 8/14/2024 at 5:36 PM, allymonty said: I've just bought a gen 1 and the passenger side front personal light is out. I ordered a replacement bulb but it's still not working. Have I ordered the wrong bulb or could there be a problem with the fixing itself? https://www.ebay.co.uk/itm/363513048214 Did you ever get to fix this, as I've got the same issue. Just going to investigate further as both bulbs are good. As an aside, has anyone found a UK source for the 8w bulbs used in the front personal light?
