bimo2700mf Posted June 30, 2022 Share Posted June 30, 2022 Hi, Is there anyone have tutorial link on how to replace license plate bulb for Alphard anh20? I bought LED bulb for license plate but I don't know how to remove the old one thanks before Bimo Quote Link to comment Share on other sites More sharing options...
Chris.ac Posted July 1, 2022 Share Posted July 1, 2022 (edited) open boot, remove the small plastic covers, bulbs are accessible through them Edited July 1, 2022 by Chris.ac Quote Link to comment Share on other sites More sharing options...
Teekay Posted July 1, 2022 Share Posted July 1, 2022 On 6/30/2022 at 12:59 PM, bimo2700mf said: Hi, Is there anyone have tutorial link on how to replace license plate bulb for Alphard anh20? I bought LED bulb for license plate but I don't know how to remove the old one thanks before Bimo Can you please share what type of bulbs are these and where did you buy them? That's second generation 2.4L Alphard? But I assume for all second generation Alphard & Vellfire it might be same bulbs Quote Link to comment Share on other sites More sharing options...
bimo2700mf Posted July 30, 2022 Author Share Posted July 30, 2022 (edited) On 7/2/2022 at 5:48 AM, Teekay said: Can you please share what type of bulbs are these and where did you buy them? That's second generation 2.4L Alphard? But I assume for all second generation Alphard & Vellfire it might be same bulbs I bought it from AliExpress very cheap and error free, it's a complete set of all interior bulbs and plus license plate bulb here's the link Rp 192,791 54%OFF | LED Interior Light Bulb Kit For Toyota Alphard Vellfire 10 20 Series 2003-2011 2012 2013 2014 Car Map Dome Trunk Canbus No Error https://a.aliexpress.com/_mOsyjPG Edited July 30, 2022 by bimo2700mf 1 Quote Link to comment Share on other sites More sharing options...
Chris.ac Posted July 30, 2022 Share Posted July 30, 2022 (edited) basically, all the sidelights, interior lights, number plate lights use the same capless bulbs, with the exception of the small boot illumination bulb, that looks like a fuse shaped bulb. These type https://www.amazon.co.uk/Autobulbs-Capless-Sidelight-Bulbs-Interior/dp/B009ZJUI90 I replaced all my 5W and 8W capless using LED ones, whiter light, and brighter. https://www.ebay.co.uk/itm/382904669684 Far far far cheaper than going to halfords or the like, 10 bulbs for under a tenner, I bought 20 and did all bulbs at once (including the ones above the Visors) Edited July 30, 2022 by Chris.ac 1 Quote Link to comment Share on other sites More sharing options...
Teekay Posted August 16, 2022 Share Posted August 16, 2022 Make thanks @Chris.ac and @bimo2700mf that's very useful information and great time saver 1 Quote Link to comment Share on other sites More sharing options...
Lesz Posted October 21, 2022 Share Posted October 21, 2022 On 7/30/2022 at 9:17 AM, Chris.ac said: basically, all the sidelights, interior lights, number plate lights use the same capless bulbs, with the exception of the small boot illumination bulb, that looks like a fuse shaped bulb. These type https://www.amazon.co.uk/Autobulbs-Capless-Sidelight-Bulbs-Interior/dp/B009ZJUI90 I replaced all my 5W and 8W capless using LED ones, whiter light, and brighter. https://www.ebay.co.uk/itm/382904669684 Far far far cheaper than going to halfords or the like, 10 bulbs for under a tenner, I bought 20 and did all bulbs at once (including the ones above the Visors) Hi Chris So which link from what you shared has the boot LED bulb? All my interior lights have the bright white LED lights installed apart from the boot which needs updating. Cheers Les Quote Link to comment Share on other sites More sharing options...
Chris.ac Posted October 21, 2022 Share Posted October 21, 2022 (edited) 3 hours ago, Lesz said: Hi Chris So which link from what you shared has the boot LED bulb? All my interior lights have the bright white LED lights installed apart from the boot which needs updating. Cheers Les The interior light? On the right side? It's the one bulb I have not changed. It looks like a fuse. Ill find link Edited October 21, 2022 by Chris.ac Quote Link to comment Share on other sites More sharing options...
Chris.ac Posted October 21, 2022 Share Posted October 21, 2022 (edited) Removed link,. the be wrong size Edited October 21, 2022 by Chris.ac Quote Link to comment Share on other sites More sharing options...
Danny Neil Posted November 19, 2023 Share Posted November 19, 2023 I thought any exterior LED bulbs would fail an MOT?? Does anyone know if this is a fact,as I would really like to fit LEDs for the reliability and better light? Quote Link to comment Share on other sites More sharing options...
Rojie Posted November 20, 2023 Share Posted November 20, 2023 19 hours ago, Danny Neil said: I thought any exterior LED bulbs would fail an MOT?? Does anyone know if this is a fact, as I would really like to fit LEDs for the reliability and better light? Hello Danny, Welcome to the Forum.. Quote Link to comment Share on other sites More sharing options...
Chris.ac Posted November 30, 2023 Share Posted November 30, 2023 2nd MOT, no problems. It's all about beam pattern, so don't put led in dipped beam. Quote Link to comment Share on other sites More sharing options...
