Hi, my Alphard is a 2009, which version is the OBD connector OBD or OBD2?
  • Replies 54
  • Views 11.4k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • Chris.ac
    Chris.ac
    I set the sliding doors to single beep when closing, and all Windows open close with long press on external door handle button or remote
  • Steve in Chester
    Steve in Chester
    I spent a bit of time going though the screens today in the car scanner app.    I’ll attach some screenshots of the various options.    This is what I see when I’ve got the app paired to
  • Steve in Chester
    Steve in Chester
    I’ll second that, you can get rid of most of the Japanese lady’s “conversation starters” though.    When I gave someone a lift they asked me if the radio stations would be in Japanese!
Posted Images
Bought an Ancel JP700 to check on engine mgt warning light. £58 on Amazon. Worked perfectly out of the box. Told me I had a PO171 ERROR - system too lean... quick check on Google pointed towards MAF or O2 sensor. Very happy with this device. If you buy an OBD you need one with JOBD functionality. (My Alphard a 2005.)
  • 9 months later...
Hi Chris,  what are you using? Can you please share a link to the OBD?
Just found this amazing item on AliExpress. Check it out!
£4.19  60%OFF | PL Ship V1.5 MINI ELM 327 BT Double PCB ELM 327 Code Reader V1.5 PIC18F25K80 for Android/PC WIFI ELM 327 USB Swith MS/HS SCAN
https://a.aliexpress.com/_ExnEGs5
Tested and works on 20 series.
Use app 'carscanner' android/iPhone.
This one, as that link has several options.
Edited by Chris.ac
Thank you Chris, very helpful! In the meantime,  I looked through other posts and websites and l I found this one at Argos, I bought it immediately and also used it to change the settings for opening and closing the windows with the smart fob. I was happy to see that they have it in stock at Argos but not at EuroCarParts.
https://www.argos.co.uk/product/9566442?istCompanyId=a74d8886-5df9-4baa-b776-166b3bf9111c&istFeedId=30f62ea9-9626-4cac-97c8-9ff3921f8558&istItemId=rxtaixixl&istBid=t&&cmpid=GS001&_$ja=tsid:59157|acid:804-872-0397|cid:20330964438|agid:|tid:|crid:|nw:x|rnd:2590488427029290232|dvc:m|adp:|mt:|loc:1007113&utm_source=Google&utm_medium=cpc&utm_campaign=20330964438&utm_term=9566442&utm_content=shopping&utm_custom1=&utm_custom2=804-872-0397&GPDP=true&gad_source=1&gclid=CjwKCAiA3JCvBhA8EiwA4kujZvx8K5Zu2Ud6DJSw77PjqyiU2g6PmfnCrPJ65npG2PPWHFghN2I6hxoCd64QAvD_BwE&gclsrc=aw.ds
