Anyone know of android radios that fit the alphard and does not require me to cut cables etc?
Must haves:
GPS, USB, Steering Wheel Control, Rear Camera, Radio, DVD Player.
Nice to have Hard drive support either USB or extra.
I Cannot find any that do not require me to cut wires 😢
I had a van catch fire and they blamed the wiring, ( I didn't install it but did repair the Ariel .)  We had an estima before this and i soldered and shrink wrapped all the wires to an iso loom.
Edited by alextovey
Xtrons are a popular kit with Alphards. Also Pioneer. You can get looms from Halfords. If you have a theatre system then a Beat-Sonic kit
Beat-Sonic full kit is the following
SLX-130 - Main adapter
CS3EP - Front and Rear camera adapter
BC12 - Reverse camera loom
BC1 - Reverse camera adapter
AVC-1 - Rear screen adapter/connector
Not the cheapest, but will restore cameras too.
Thanks for that, was just on the Beat-Sonic site and saw the main kit mentioned to add CS-1, but couldn't find it, saw the CS3EP and was hazarding a guess that was the replacement 😃
  • 5 months later...
Hi Guys,
I realise that this is an old thread, however this is the model I have just put into my Gen 1 Alphard
https://www.ebay.co.uk/itm/Android-7-1-Car-Stereo-GPS-DAB-TOYOTA-Camry-COROLLA-Prado-RAV4-VIOS-HILUX-Yaris/162814193695?hash=item25e87b701f:g:Gs4AAOSwKQ9aO4R7:rk:1:pf:0
Fits like a dream with no additional surrounds, has wi-fi and sat nav
Also has front and rear camera outlets
Evening Alex,
I seem to remember that it went straight in, as the unit was sold as Toyota compatible,  Fitted it last year so brain is a little foggy - its my age
I will see if I can dig out the manual and post a copy of the wiring diagram  tomorrow
I will have a look at the doors over the weekend if its dry
Good Luck with the Doors, If i remember correctly from facebook post's there is a small screw on the bulkhead of the door frame which needs removing first to get the cover off.
You able to scan the whole booklet with any wiring or ISO plug connectors :) We can add it to our resources section then :) This might help alot of people looking to change it as well.
On 11/29/2018 at 1:17 PM, Steve Shears said:
found the  wiring manual  hopefully this will help someone,
its got all of the pin-outs on
alphard android radio.pdf
there's nothing but a blank page mate
