12 hours ago, Sorin said:
Hi Teekay, I have a question: I bought recently a OBDII that I can use to scan my 2012 Vellfire. My phone connects to it via WiFi and I have an mobile app. https://www.eurocarparts.com/p/streetwize-obdii-code-reader-for-android-and-ios-553999810?gad_source=1&gclid=CjwKCAiA3JCvBhA8EiwA4kujZt5VBcVRzw1spzBEo3PjEV-_5JrKMRPyZnSpGxpf-RFqik5o2rGPARoCAL4QAvD_BwE . Is this the same with the VCI cable? Can I use it with the Techstream software?  Also, what is the difference between the keys with different frequencies, 312, 313 and 414 Mhz? I need a 4 buttons key and I am not sure which is the correct one for me!
No, the cheapest way to add a new fob is via techstream as detailed above.
There are some standalone diagnostic tools that can do it, but they are significantly more expensive, to the point that a 2nd hand laptop and techstream is cheaper.
I have a vci cable, and a WiFi adaptor that works with techstream.
This is the fob you need for your hybrid.
You can check the listing,  it tells you the circuit board number
https://www.ebay.co.uk/itm/255021256169
Thank you Chris, now I understand how to match a key to my car, by the pcb number! You are a life saviour!
I finally managed to programme a new key fob for my Vellfire 2012 with Techstream. The whole process is a bit annoying but I manged to do it in the end. If anyneeds help, I am more than happy to help with details!
  • 4 months later...
On 10/7/2018 at 10:18 AM, Djakninn said:
Follow this to the 'T' and it should work no problem with the smart fobs to open and close the doors (It looks convoluted, but worked for me on 1st attempt)
Before starting make sure you have no mobile phone in your possession/close by.
1. Sit in the drivers seat - Driver door open, key out of ignition
2. Within 5 seconds, place key in ignition and take it out x 2 (Do not turn key)
3. Within 40 Seconds, close the drivers door and open x 2
4. Put key back in ignition (Do not turn key) and take it out
5. Within 40 Seconds, close the drivers door and open x 2
6. Key back in ignition and leave it in
7. Close drivers door
8. Turn key in ignition (Without starting car)
9. Turn key back and take key out of the ignition
(The door locks should automatically do a cycle - If nothing happens, you've done something wrong and will have to restart the re-programming again from the start)
Once the door locks have did their cycle :
10. Within 40 seconds press lock and unlock buttons on fob together for 2 secoonds
11. Then press lock button on fob for 2 seconds (The door locks should do a cycle again, if they do not complete a cycle, repeat step 10 and 11 again. If the door locks cycle twice, it also means that the re-programming has failed so repeat steps 10 and 11 again)
I wonder if this works for 2nd Gen Alphards/Vellfires?
No. There is no key hole on the 2nd gen. This method uses the chip reader that is in the keyhole surround.
The 1st gen has a far simpler security ecu.
  • 6 months later...
1 hour ago, Bill-HongKonger said:
Hi guys,
Curious how to know the frequency is my key fob? It's a 2004 3.0 Alphard MNH10, there are three buttons on the fob
on this link there are three frequency not sure which...
https://www.aliexpress.com/item/1005003598907017.html#nav-specification
Regards,
Bill.
I took mine to a local locksmith (ARC in Stevenage) and they scanned my existing key to determine the frequency it used.
Then I looked on ebay for fobs and key blanks that matched that frequency and buttons.
There was a fair bit of faff around getting the keys programmed but the cutting went well.
They needed a sort of OBD patch panel for their fob programmer to get it's expected 12v from the vehicle.
But they have done it once now so when they get another 2005 Alphard it should be easier for the next person.
I wanted a second key for my Alphard so I went to my local locksmith. He ordered a suitable blank and cut it and also programmed a separate "bipper" which serves to open the locks. I did ask if it was possible to get an integral device but he said he couldn't...
I bought a genuine Toyota three button key from ebay and programmed by myself using the open open close close door plug plug instructions
all three buttons work fine but it couldnt start my car, it just keep cranking. it of course starts when use back my original key
also I notice the immobilize icon (the red car icon with a key on it) didnt go away when using the new key, so i reckon there is something more I need to do on the new key programming but no idea what to do other than than the open open close close steps..
Anyone encounter this before?
ebay link fyi: https://www.ebay.co.uk/itm/186459254997?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=Z-VLY7pmSYm&sssrc=2047675&ssuid=7bdk6kbet8i&widget_ver=artemis&media=COPY
P.S. the part number on my original car key is the same as I bought on ebay which is 58050
Thanks!
Thanks!
Yes, the new key will need the immobilser activating.
What key type did you buy, the earlier Gen1 is a different key to the facelift.
Are you sure you bought the correct one?
Auto-electrician is your best bet.
my bad....... overlooked the 2nd part programming instructions from the seller
transponder key programming attached fyi
Note, this process needs a Master key, or states that it does.
It is much easier, but by no means cheap, to get a competent auto-locksmith to it for you.
If you do, you may end up with several keys that are all Masters !
yep..... I lost one key and just tried to copy a new one
Thanks !!
