pjpern Posted September 12, 2024 Posted September 12, 2024 My heating isn't up to much. Air con cooling is great and fans are fine but it doesn't really give out much heat. I turned it all the way up and the dial showing engine heat started to go right down. Is this normal or what can I do? ATH20 2012
Rojie Posted September 12, 2024 Posted September 12, 2024 1 hour ago, pjpern said: My heating isn't up to much. Air con cooling is great and fans are fine but it doesn't really give out much heat. I turned it all the way up and the dial showing engine heat started to go right down. Is this normal or what can I do? ATH20 2012 On an ealrier model (than yours) this sounds like you may need your heater circuit bleeding of air. It is covered here somewhere on the Forum
Quimbasher Posted October 9, 2024 Posted October 9, 2024 On 9/12/2024 at 6:29 PM, pjpern said: My heating isn't up to much. Air con cooling is great and fans are fine but it doesn't really give out much heat. I turned it all the way up and the dial showing engine heat started to go right down. Is this normal or what can I do? ATH20 2012 Iv had this before on a previous car, it turned out to be a sticky thermostat. Does it take some time for the engine temp to come up from a cold start?
pjpern Posted October 9, 2024 Author Posted October 9, 2024 Strangely enough, the engine temp goes up really fast! Better than any other car I've had too!
BigNev Posted October 9, 2024 Posted October 9, 2024 Hi there! Have you checked to see that your radiator is full of coolant?
Register a new accountSign in
