My heating isn't up to much. Air con cooling is great and fans are fine but it doesn't really give out much heat. I turned it all the way up and the dial showing engine heat started to go right down. Is this normal or what can I do? ATH20 2012
On an ealrier model (than yours) this sounds like you may need your heater circuit bleeding of air.
It is covered here somewhere on the Forum
Iv had this before on a previous car, it turned out to be a sticky thermostat. Does it take some time for the engine temp to come up from a cold start?
Strangely enough, the engine temp goes up really fast! Better than any other car I've had too!
Hi there!
Have you checked to see that your radiator is full of coolant?
