I had my axle bushes changed last October for the mot as they failed I been having a knocking noise coming from the rear so took my Alphard back to where I had the mot done they put it up on the ramp and I was shocked to find both axle bushes have failed again the mechanic who did the job said he seen nothing like it he said they was worse than the old ones I supplied the bushes which I bought off eBay £45 a pair there are dearer ones on eBay £85 a pair I contacted the company JDM in Leominster his add 2 year warranty unlimited warranty won’t honour the warranty because your only covered for 3 months on eBay and he knows I have no chance getting a refund beware the cheaper ones on eBay are cheap sub standard rubbish . Learnt a very valuable lesson today and a costly one have ordered new bushes heavy duty ones and going to cost me again £350 labour to have them fitted
Absolutely disgusting!
Thank you for the heads up on that company.
Problem is not just jdm selling them it seems eBay has been flooded with the cheap ones will give update when new ones arrive and fitted want to compare the old ones to the new ones
Are original Toyota ones still available?
I'm just wondering about the potential extra cost of them, against the possibly much earlier failure of pattern parts....
But if the heavy duty ones you've ordered for this time are from a good source, I'd certainly hope they'd be up to the task 🤞 or maybe even better than original!
hi Neville genuine Toyota £180 + vat each I wont pay that . the ones i have gone for are £85 a pair just looking at them they are far better quality the cheap ones hardly have any rubber in them and they are heavier than the cheap ones .
Woh thats seriously heavy money!!
I'd do the same as you on that then!!
Are you sure genuine ones are £180+VAT each? Amayama are selling OEM for about £45 each delivered from Japan.
Funny enough I was talking to a Mazda MX5 owner earlier today and told him about amayama.com and he was rather shocked that a part he had been looking for was around a third of the price on amayama. A good source it must be said.
Edited by Gamith
Changed the text for clarity.
I eventually had my trailing arm bushes done, about 2 months ago by my local mechanic Colin Campbell. He said they were a swine to do. I must find out where he got the bushes from. Total Job came to £555.. He made a punch to knock them out
Booked in with Ben hau at Harmony motors in birmingham on Monday for rear bushes to be done. He has quoted £350 for the job, which seems reasonable.
Hopefully he uses decent quality bushes...
Alphie is still pulling to the left, with a lot of rear knocking which sounds like the passenger rear door area.
Noticed today that the rear driver tyre that i've had on for 8 months or less is seriously worn on the inner edge.
I'm praying that this will be a miracle cure. Fingers crossed.
Ask Ben if he can check the offside rear geometry.
Good shout.....do you think that they just bolt the rear subframe back up in to a set position, or if it'd on an elongated hole to allow some kind of adjustment?
It seems odd that Toyota wouldn't think of a way to adjust.
I guess if not, then an entire new rear subframe would be necessary, due to being bent.
Quick update:
Ben Hau did a good job fitting my rear bushes in 3 hrs, and showed me that the the originals were indeed split, but not that bad in his opinion.
He says that the rear geometry is sound, so probably not the culprit with regards to pulling left.
He recommended a good tyre fitter/ Alignment specialist in Dudley to have the tracking done (again) as they have the correct set up on their machine.
The rear driver side un-even tyre wear is very common on the Gen 1 apparently, and not a lot I can do other than go heavy duty tyres, which I already have. Still can't believe that Toyota don't have a way of adjusting this part of the suspension set up.....:(
The very annoying rattling from the passenger rear door area is still as prevalent as ever.
I've removed the door card and checked for anything untoward-can't find a thing there either.....at a loss to what it could be now.
Also removed everything from the car not bolted down, and put foam around seatbelt mount bolts, and behind plastic wheel arches.
It could be the door itself on it's rail, but the driver rear door rattles just as much when wiggled with the door half open, and doesn't make any noise when driving so not convinced it's that either....
Doing my head in.
