5 minutes ago, Michael Brown said:
After a 12v  battery change, what is the sequense to get the windows working again, as only drivers door window works
From memory you just lower each window, using the switch in the door for that window (not the drivers door switches).
Down and up, possibly a couple of times each.
If you have a moon roof you may need to do that too.
Yes as Rojie said, but then the front ones to enable auto close and auto open you open each one and hold the button for 5 seconds, then close and once closed hold for 5 seconds and job done.
Register a new account
Sign in
