I appear to have lost all the lighting on my instrument panel (speedo rev counter etc.)
Any ideas on where I start looking?
My Mot is due in a couple of weeks, so need to sort it fairly quickly.
Thanks.
35 minutes ago, Dick Powell said:
Thanks.
Do your clearance Sonars still work ?
I believe they may have a common fuse with the instrument lighting.
Do all the warning lights come on before starting ?
All lights are LED's soldered onto the vehicle speedo's itself. Rojie is correct they will be the fuses under the drivers side panel. you have to be a contorstionist to get at them.
I haven't got parking sensors, just cameras. All the warning lights seem to be working fine.
I'll see if I can find the drivers side fuses. If they're anything like the passengers side, I'm dreading that! 🫣
The passenger side fuses are worse than the the drivers side.
Taking the glove box out may help but I usually end up either upside down with my head where the passengers feet would be or with a flexible mirror.
Whichever way you get access to them a pair of Bent Nose Pliers will help.
Something like this - mine aren't 90 degrees but about 45.
medium
