Dick Powell Posted May 23 Posted May 23 Hi, I appear to have lost all the lighting on my instrument panel (speedo rev counter etc.) Any ideas on where I start looking? My Mot is due in a couple of weeks, so need to sort it fairly quickly. Thanks.
Rojie Posted May 23 Posted May 23 35 minutes ago, Dick Powell said: Hi, I appear to have lost all the lighting on my instrument panel (speedo rev counter etc.) Any ideas on where I start looking? My Mot is due in a couple of weeks, so need to sort it fairly quickly. Thanks. Do your clearance Sonars still work ? I believe they may have a common fuse with the instrument lighting. Do all the warning lights come on before starting ?
MonsterS Posted May 23 Posted May 23 All lights are LED's soldered onto the vehicle speedo's itself. Rojie is correct they will be the fuses under the drivers side panel. you have to be a contorstionist to get at them.
Dick Powell Posted May 23 Author Posted May 23 2 hours ago, Rojie said: Do your clearance Sonars still work ? I believe they may have a common fuse with the instrument lighting. Do all the warning lights come on before starting ? I haven't got parking sensors, just cameras. All the warning lights seem to be working fine.
Dick Powell Posted May 23 Author Posted May 23 1 hour ago, MonsterS said: All lights are LED's soldered onto the vehicle speedo's itself. Rojie is correct they will be the fuses under the drivers side panel. you have to be a contorstionist to get at them. I'll see if I can find the drivers side fuses. If they're anything like the passengers side, I'm dreading that! 🫣
Gamith Posted May 23 Posted May 23 The passenger side fuses are worse than the the drivers side. Taking the glove box out may help but I usually end up either upside down with my head where the passengers feet would be or with a flexible mirror. Whichever way you get access to them a pair of Bent Nose Pliers will help. Something like this - mine aren't 90 degrees but about 45.
