I have a 2002 MH10 V6 auto with a stuck/seized starter solenoid. New Acre (my local specialist) tell me they wouldn't be able to do anything for a couple of months. Can anyone recommend another specialist who could change the starter motor for me, ideally in the Midlands area.
hello peter try simon contract mechanics 01926-612932    07551578462   give him a call say lee gave you his number great genuine guy he will look after you if he dont answer the phone leave a voice message and name and number he will call you back works on his own or drop a text message he will all ways reply or you can try stuart spencer autos in dudley i bought my alphard off him and he also does repairs
Thanks for that feedback. Very useful. I was taking the view that it was beyond my above average mechanicing skills, and the lack of an English workshop manual as a guide. Having checked a video, I'm sure I can do it.
you could just change the solenoid contacts rather than the whole unit
Hi last year I got my Alfie's starter motor repair for 95GBP in Stoke on Trent. That's including repair and taking it from the car and putting back together. Bit far from Midlands but you could find a shop that does only those repairs in Midlands.
12 hours ago, Picasso said:
I’m sure you can just take your time
My brain sometimes goes into full negative mode when looking at something new. Probably something to do with my advancing years! Thanks for your positive thoughts. As for replacement starter, am I good to just go by engine size and vehicle age, or are there differences I need to know. Its a 3.0l V6 from 2002.
See link for part numbers, then you can check online e.g. eBay, Autodoc, etc https://www.amayama.com/en/genuine-catalogs/epc/toyota-japan/alphard/MNH10W/152282/engine/1904
Having watched a couple of YouTube videos of removing the starter from other Toyota models, it proved to be a remarkably straightforward job. Basically the steps are remove the battery, remove the aircleaner assembly and then remove the two bolts securing the starter to the cylinder block. Took me all of 40 minutes. Then hit the most mind boggling snag I have ever encountered, and I mean EVER! The starter motor flange is corroded to the cylinder block and no amount of blows to the flange edge seems to want to break the bond.
Has anyone encountered anything like this before and has anyone got any realstic suggestions about breaking aluminium corrosion, especially where access to the joint is very limited to large tools or objects. I have the new starter and the old one is not needed as a return.
We have a trip planned for the first weekend in July, and wondering if we will make it!
3.0 are known for it they rust them selves in the shoulder of the starter motor is smouth slides in but over time they get stuck in i have known people to brake the starter motor to get it out
Thats how mine is coming out. Current left with the front cone and pinion still stuck in the mounting hole. Cant see a way to collapse the cone without the possibility of it all dropping in to the bellhousing. Have instilled the help of a neighbour who is a commercial vehicle mechanic. So far his chisels have done far more than mine did!
New starter fitted and engine starting without issues. This is how the old one came out. The cone with the front pinion was the real problem area.
Just taken the van for a run and noticed the MIL was on. Disconnected the MAF and a black connector at the rear of the cylinder head while removing the starter. Both replaced OK. Is it likely the MIL will go out on its own, or does it need further checks.
Chuffing heck!!
That was seriously stuck in there!
Far too happy where it was and wanted to stay!
