I have a Series 20 Vellfire with 3.5L Engine.
I would like to change the transmission fluid but having some trouble sourcing genuine parts for it.
I have tried to use the Toyota parts catalogue but with little success and there are lots of cheap floating around online.
Does anyone know what the genuine part number(s) is/are for the Transmission filter and gasket (if separate).
Hello Nic i help lots of members on here with part no.s and drawings if you pm your reg no. or vin no. i will get the part no.s for you
5 hours ago, matrixprotein said:
There is a an official toyota manual for this somewhere for this job. we had a PDF and downloaded it and read the step by step how to change the fluid properly.
i will ask my friend if he still has it.
For mine, same engine / transmission as yours, the filter can be this Blueprint option, ADT32137, came with the gasket, or equivalent, and the fluid is the Toyota ATF WS, for World Standard apparently.
Edited by BigNev
hi Nic as bignev says you got blue print  ADT32137 this comes with the gasket and filter blueprint is a good jdm brand or if you want to go genuine toyota only parts buy from partsouq  genuine parts only they in dubia but shipping is very quick no import charges if you use fedex as the courier here is a link added parts to basket you need to buy filter and gasket seperatly https://partsouq.com/en/shop/shoppingCart/view  oe no.s for each item next to each part.
yeah, it seems a little of an unknown as to how much fluid is needed.
I've just ordered 5 litres. So once I get started, I'll take some photos etc to show the process to add to this Forum.
you won't use the whole 5, but understandable you need to ensure you have enough. I did also top up again as there is some in the torque converter i wanted to ensure i change as much as possible,
