Front windscreen washer not working
Front windscreen washer not working can’t hear pump. Rear working ok. Any ideas.
Den
Yeah the pump is knackered.
Check:
fluid level
is the 'hose' loose
with a multimeter whether power is getting to the pump when activated,
if any of those are not Ok then fix them
If they are Ok then suspect the pump.
You could try removing it and flushing it out - maybe the filter is, or fan blades are, blocked
All for n0w.
