wheel nut
has anyone got a clue where I can get wheel nut for a 2007 Alphard 2.3l ?
thanks in advance
It looks like part number 42601C is worth looking for but there are three types on Amayama.com for my 2005 facelift version, yours may well be different. Once you have the right number you can order from them or look on other popular websites.
There may be scrap(pies/ yards) that may have them also.
42601C is the index number in the parts list, not the part number. The numbers listed underneath (90942-010xx) are the part numbers - copy the text into Google Translate to get what the Japanese says to work out the differences. Looks like there are different versions pre and post 2005 and based on the different kinds/sizes of wheels.
If you start by putting your frame number (ANH10-xxxxxxx) into the search box of Amayama it'll show the parts for your specific trim level, although it doesn't always know about factory options.
(I would also check your type A/B/C against the picture, as it's possible it has different wheel than factory)
Although if you aren't fussy about design there are presumably also generic ones which will fit.
