Hybrid water pump wiring diagram
I have a problem with the hybrid water coolant pump and it seems there is a dodgy wire or connection as only 2v arrives at the water pump. This causes the vehicle to overheat. Can someone share the wiring diagram?
Best i got for you i'm afraid. You might need to run through google translate.
hisat015.pdf hisat016.pdf
Hi
Hi, the power feed comes from the hybrid computer, the inverter decides when the pump should run, which is anything above 5 C water temp. The hybrid computer is behind the engine ECU which is behind the glove box
hdam0430.pdf
Thanks. Are these diagrams correct for the Ath10W model? Seems there are three generations and the wiring diagrams are quite different…
Yes they are for the ATH10 hybrid from the official Toyota manual, translated from Japanese. There is slight differences from the early models and the face-lift models 2005 but that is indicated on the diagrams.
I think the hisat015 and 016 diagrams are for the heating, cooling and air con systems. The Hybrid cooling pump comes under the hybrid system.
