Yesterday I experienced an intermittant shudder while driving at constant speed, symptoms were:
- was doing constrant speed on level road
- car appeared to shudder like trying to change gear however only briefly happened
- no warning lights came on
- done ~95K miles
Questions:
- Anyone experienced similar
- is it worth changing gearbox oil
thanks in advance
Hi Gavins,
Worth changing gearbox fluid. is the shudder constant still? When was the last wheel alignment done?
I had a shudder caused by the tie end rods once they were replaced it stopped.
Gavins, my shuddering issue was caused by a extremely dirty MAF sensor.  problem prevalent especially in hilly situations.  CEL would turn on most times though.   I thought it might have been a bad CVT, and did a drain and fill of the fluid. ANSEL JP700 code reader gave fuel system related warning (i have a long post on this forum).
replaced MAF and issue went away.
