Hi everyone
I know its Winter but my 2007 v6 is running a lot cooler than usual..the needle stays below the bottom of the guage for 5 min or more then slowly creeps up to a 1/3rd of the scale. It used to be 1/2 way. Also not as much heat through the vents.. I suspect thermostat but it was only changed last year. Any help out there?  She still is whisper quiet and runs like a dream. Should I be worried?
Check coolant levels in radiator, top it up till you cannot get anymore in. Then you should be getting heat out of the vents
Hi Mike, thanks your advice, will try that today.👍
I recall along time ago going over the tubes of the cooling system (of a totally different car) squeezing them to make sure the water moves around - obviously you don't want the radiator to be absolutely full at this point unless you like it bubbling out.
Other items:
check the tension of the water pump belt,
you could try laying a sheet under the car and see if there are any water drips in case it's leaking out somewhere.
It would be nice to check whether the water pump itself is working effectively but I don't know of a way.
Get a sheet of cardboard or something and put it over the front of the radiator and see whether it makes a difference.
Register a new account
Sign in
