matrixprotein Posted Thursday at 01:25 PM Posted Thursday at 01:25 PM Hi, I have a Series 20 Vellfire with 3.5L Engine. I would like to change the transmission fluid but having some trouble sourcing genuine parts for it. I have tried to use the Toyota parts catalogue but with little success and there are lots of cheap floating around online. Does anyone know what the genuine part number(s) is/are for the Transmission filter and gasket (if separate). Thanks
Picasso Posted Thursday at 03:47 PM Posted Thursday at 03:47 PM Hello Nic i help lots of members on here with part no.s and drawings if you pm your reg no. or vin no. i will get the part no.s for you
matrixprotein Posted Thursday at 04:22 PM Author Posted Thursday at 04:22 PM Hello Picasso. That's very helpful so thank you. My reg is BW08YDE Thanks for much
Alphard Club Posted Thursday at 06:58 PM Posted Thursday at 06:58 PM 5 hours ago, matrixprotein said: Hi, I have a Series 20 Vellfire with 3.5L Engine. I would like to change the transmission fluid but having some trouble sourcing genuine parts for it. I have tried to use the Toyota parts catalogue but with little success and there are lots of cheap floating around online. Does anyone know what the genuine part number(s) is/are for the Transmission filter and gasket (if separate). Thanks There is a an official toyota manual for this somewhere for this job. we had a PDF and downloaded it and read the step by step how to change the fluid properly. i will ask my friend if he still has it.
BigNev Posted Thursday at 09:30 PM Posted Thursday at 09:30 PM (edited) For mine, same engine / transmission as yours, the filter can be this Blueprint option, ADT32137, came with the gasket, or equivalent, and the fluid is the Toyota ATF WS, for World Standard apparently. Edited Thursday at 09:31 PM by BigNev 1
Picasso Posted Friday at 07:34 AM Posted Friday at 07:34 AM hi Nic as bignev says you got blue print ADT32137 this comes with the gasket and filter blueprint is a good jdm brand or if you want to go genuine toyota only parts buy from partsouq genuine parts only they in dubia but shipping is very quick no import charges if you use fedex as the courier here is a link added parts to basket you need to buy filter and gasket seperatly https://partsouq.com/en/shop/shoppingCart/view oe no.s for each item next to each part. 1
matrixprotein Posted Friday at 10:18 AM Author Posted Friday at 10:18 AM Thanks guys. I've ordered the blueprint part and will order the transmission oil too then I should be good to go
Alphard Club Posted Friday at 10:30 AM Posted Friday at 10:30 AM shame you are not near me as I have 3 bottles of Toyota WS on my shelf, but posting fluids is a pain.
matrixprotein Posted Friday at 11:36 AM Author Posted Friday at 11:36 AM yeah, it seems a little of an unknown as to how much fluid is needed. I've just ordered 5 litres. So once I get started, I'll take some photos etc to show the process to add to this Forum.
Alphard Club Posted Friday at 12:31 PM Posted Friday at 12:31 PM you won't use the whole 5, but understandable you need to ensure you have enough. I did also top up again as there is some in the torque converter i wanted to ensure i change as much as possible, 1
Jimmympv Posted Saturday at 08:32 PM Posted Saturday at 08:32 PM I've been looking in to this recently, I believe the 3.5 V6 uses the U660E transmission and that Toyota classed it as a "sealed" system not meant to be opened as part of a regular service, just drain and fill every 40,000-50,000 miles, 3.5-4l of Toyota WS to replace what comes out (7-8l if completely replacing) and then check fluid levels at 40c Wouldn't hurt to replace the lot but I probably wouldn't be doing it every service.
matrixprotein Posted Sunday at 08:23 AM Author Posted Sunday at 08:23 AM 11 hours ago, Jimmympv said: I've been looking in to this recently, I believe the 3.5 V6 uses the U660E transmission and that Toyota classed it as a "sealed" system not meant to be opened as part of a regular service, just drain and fill every 40,000-50,000 miles, 3.5-4l of Toyota WS to replace what comes out (7-8l if completely replacing) and then check fluid levels at 40c Wouldn't hurt to replace the lot but I probably wouldn't be doing it every service. yeah I won't be flushing the whole system. As you said, it will just be drain and fill but I will remove the sump to access the filter and change this too. I only recently bought the car and have no record of the fluid being changed 1
Alphard Club Posted Sunday at 09:51 AM Posted Sunday at 09:51 AM 1 hour ago, matrixprotein said: yeah I won't be flushing the whole system. As you said, it will just be drain and fill but I will remove the sump to access the filter and change this too. I only recently bought the car and have no record of the fluid being changed peace of mind all fluid changed, always do it. i did think of changing anti roll bar bushes as i always change them on older cars, makes a difference... until i saw where they were located... yeah i left them. 1
BigNev Posted Sunday at 10:06 AM Posted Sunday at 10:06 AM Obviously I agree with you guys, as I did that too!
