Saf Posted Friday at 04:40 PM Posted Friday at 04:40 PM Vehicle is starting and when I put on D or Reverse it moves on idle speed. When I accelerate their is no rev. I tried changing battery. Still the issue is same
Alphard Club Posted Friday at 04:44 PM Posted Friday at 04:44 PM Hi Saf Do you have an yellow engine light on the dash??
Gamith Posted Friday at 06:19 PM Posted Friday at 06:19 PM If you have a JODB compatible reader that should, hopefully give some clues. Clear the existing codes and wait for it to happen again then read again. It may be something like an air or fuel filter that needs replacing, but more likely would be a lambda sensor - the code scanner will point you in the right direction - there are lots of post on the forum.
BigNev Posted Friday at 07:32 PM Posted Friday at 07:32 PM Will it rev with the accelerator pedal, out of gear? If not, suspect the throttle position sensor.
Saf Posted Friday at 07:34 PM Author Posted Friday at 07:34 PM 2 hours ago, Alphard Club said: Hi Saf Do you have an yellow engine light on the dash?? Yes. I get the check light.
Saf Posted Friday at 07:36 PM Author Posted Friday at 07:36 PM 3 minutes ago, BigNev said: Will it rev with the accelerator pedal, out of gear? If not, suspect the throttle position sensor. Thank you. No it dose not rev on ideal (N) position
Saf Posted yesterday at 04:39 AM Author Posted yesterday at 04:39 AM 10 hours ago, Gamith said: If you have a JODB compatible reader that should, hopefully give some clues. Clear the existing codes and wait for it to happen again then read again. It may be something like an air or fuel filter that needs replacing, but more likely would be a lambda sensor - the code scanner will point you in the right direction - there are lots of post on the forum. Thank You All for the help. So it should be a (J OBD) or (OBD J) ? OBD 2 will not work? I'm in Canada. Thank You.
Alphard Club Posted yesterday at 07:37 AM Posted yesterday at 07:37 AM need to be JOBD icarsoft scanner for Toyota (needs to be Toyota/Lexus version)
BigNev Posted 13 hours ago Posted 13 hours ago On 8/15/2025 at 8:32 PM, BigNev said: Will it rev with the accelerator pedal, out of gear? If not, suspect the throttle position sensor. Or also the motor for the throttle actuator? 1
