7 minutes ago, Jimmympv said:
Just picked up my 2012 Alphard today and have the exact symptoms described here. Was a bit disappointed but fingers crossed the cheapest solution sorts it!
Just to let you know how my repair went, the mechanic changed it in 30 mins, he'd never changed one before so I linked the video above how to do it. He reached up without doing any of what the video showed but he was obviously pretty competant as a mechanic and very flexible 🤣 Good luck, hope it solve the problem 👍🏻
  • Thanks 1
Can I respectfully request you add the details of your mechanic to the servicing section.
There is a small section for a mention for individuals and businesses who  are competent to work on Alphards; yours would be a worthy addition.
All done Roger 👍🏻
I finally got the time to take a look at this and after pulling everything apart turns out there was absolutely nothing wrong with the bush that was in there, it looked brand new ☹️ replaced it anyway so back to square one.
This is what I found when I picked mine up too. It may require a new column. If you want to check it, you could remove the damper bush and wiggle the spider that holds it in place on the column. If there is play or a knocking then unfortunately its a 2nd hand or new column needed i believe.
The backlash is in the worm gear within the lower part of the column. Its very slight but whem driving over rough surface at slow speed cam be very loud in the cabin. I stripped mine and packed with grease but this only dampened the rattle for a week or so. Then had to replace the column with one from amayama.  Hope you get it sorted.
  • 4 months later...
I've done the same as you today - tried to replace the damper bush, only to find the one in there was perfectly good.
Can I ask - when you say 'replace the column with one from Amayama' - did you replace the upper column that the spider is part of, or did you replace the lower part (intermediate shaft), like the one Picasso linked to?
Hi Maxim i  just purchased the Steering shaft with twin U Joints off Aliexpress and Couriered to NZ for $90 all up.. The U joints look pretty good but i guess ill know once i fit it this weekend.
Hi. Thanks.
In the end I bought the aftermarket intermediate shaft off eBay.
That looked good and the universal joints were smoother and stiffer, however that still didn't fix my issue when fitted.
Then I bought a second hand upper steering column and that did fix my issue thankfully. The noise was due to slight play in the connection between steering column and the power steering motor interface. Hardly noticeable amount of play when off the vehicle, but it rattled massively when going over bumps.
What price are we looking at for this part? Also do you have the part number? I have a feeling this is the issue with mine, all of the knocking/vibration comes from right behind the steering wheel. Don't really get any noise rocking the wheel side to side or at full lock etc. If you drive over a gravel drive for example it'll rattle like hell, on a regular road it will be fine until you hit a pot hole or at certain speeds when the frequency must vibrate just right to make it rattle. Sometimes it'll knock going over a speed bump sometimes it won't.
It has absolutely no effect on the handling whatsoever it's more of an annoyance than anything.
Which part do you mean?
In order of least to most expensive:
- damper (£20 ish for genuine Toyota)
- intermediate shaft (£50 ish for aftermarket)
- (upper) steering column (I paid £170 for secondhand one, delivered).
Steering column part number for mine was
4520A-58010 according to Amayama.
Note that if you're looking on eBay, most of the listings have the part number 80960-58010.
That's actually the part number for the electric motor, but if the column and motor have been removed as one assembly, 80960-58010 is the most visible part number.
  • Thanks 1
That upper steering column sounds like the part I need. I already changed the bush, the one already in there looked brand new still but swapped it out anyway.
It sounds like it almost emanates from right behind the steering wheel as if somethings loose and rattling about when it happens.
There’s a place called Osaka in Newport that specialises in Toyota and Lexus imports so I might just book it in with them and get it looked at as it’s due a full service and MOT soon, I was planning on servicing it myself but can never find the time!
On 5/6/2024 at 3:15 PM, Garnet said:
I have a similar AnH20 steering column rattle!….I have changed the damper , just reach up and you can unbolt the motor , fish out old damper and refit new one, in my case it wasnt that!….it serms to be play in the actual column splines…so will need to pull the column head off completely , a new one is at least £5-600!, (4520A-58010)
Me too, apparantly it was an issue with the early ones, the plastic gear wears (according to Just Japenesse in wigan, very helpful).  Still I can confirm its a fast job to do the damper, only mine was just fine.  It could be the column joints but I'm sure mine is £5-600 column gearbox assembly.
Gaaah! I didn’t realise this was in the later model Alphard section. I just went to do this on my 04, dropped the steering wheel and it’s totally different!
Hello John,
1 hour ago, Rojie said:
Hello John,
thanks. Didn’t realise this was my 1st post, been on here a while. Turns out I’ve somehow locked the immobiliser, it won’t turn off after putting the key in.
the ring round the key hole fell apart when I took the trim off. There’s a small circuit board with the green led. Is that immobiliser related? Looks like 2 connections are broken.
weirdly I don’t think the immobiliser has ever worked, never seen the flashing key light on the dash.
is there a way to sort it?
Edited by JonJones
Added pics
Hi everyone,
For those that have done this job, a quick question.  How did you remove the white plastic air ducking some from the centre of the console?  It inhibits dropping the steering wheel unless removed.
Thanks in advice for any pointers.
there is little plastic clip on top -- cannot see it
if you pull it hard you will break it ( i did )
you still can put things back together even with broken clip
other clips should be visible to press and pull
