5 minutes ago, crazymac680 said:
Day 19
1 hour.
Cleaned up the sump and reinstalled.
Then installed a new oil filter.
If my new exhaust manifold comes tomorrow I might have her running.
Day 19
1 hour.
Epic journey.
Here's wishing you every success on behalf of all Club members
  • Replies 58
  • Views 5.3k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • You have my entire admiration for even tackling this job (especially in your somewhat remote location).
  • Michael Brown
    Michael Brown
    You are very brave to entertain doing this job, I hope it all works out fine for you. Looking at the gravel drive might have been an idea to lay a tarp on the ground under the vehicle to retain anythi
  • Day 13 - 2 hours So I spent a lot of time waiting for parts. When I was ready to install the head bolts. I realised that the new ones didn't come with washers and I'd thrown away the old😂. D
Posted Images
This post was recognized by Rojie!
crazymac680 was awarded the badge 'Superstar' and 50 points.
"The Club recognises the magnitude of the task, and all the effort you have provided to keep all Club Members informed with photographs and commentary."
Day 20
3 hours
I'd decided to order a new exhaust manifold as I'd damaged a bolt hole on mine. It arrived today and it was the wrong one. It seems the 2005 2.4 is a different manifold from my 2002 2.4.
Mostly the same apart from a slightly different angle where it joins the exhaust and those two bolts are in a slightly different place.
So I was forced to repair my own.
I filled the hole with weld. Then drilled and tapped a new thread. Actually went quite smoothly.
I then had to remove 3 cut off bolts from the heat shield. 2 removed and that will need to do🤣.
Installed the manifold
Filled with oil
Filled with water.
Installed battery.
I'd planned on turning over with the fuel pump disconnected but I was too lazy to find the fuse.
She started on 3 quick key turn. Hunted for about 5 seconds and then purred like a kitten.
Let it get to temperature and fans kick in. Kept checking the water.
Turned her off and checked all the levels half an hour later.
Took her for a spin and she is driving like she hasn't been off the road.
I'll add up the hours and my final thoughts in a couple of days🤣
Wooho, blooming fantastic!!
Nice, well done and a great result.
Yer a brave man Gunga Dinn!
Many congratulations, can’t imagine the number of lost sleep hours thinking ‘what do I do next?’
  • 6 months later...
Do you know how much a garage would have charged
