Needing a spare 17" alloy wheel
check the under-body holder as the cage won't fit a full-size tyre without some serious modification - though i suspect that getting some suitable thick wire and getting the bends right might work i don't know how it would be with hitting the ground when going up and down slopes etc.
Hi guys!
I got an almost new 17" spacesaver off a Lexus IS220, from an ebay trade seller in Bury, North Manchester, for £36 delivered.
Yes, I tried it on and it clears the calipers!
A few little marks on the metal, and the tyre still has the moulding pips.
It sits in the back as the lpg tank is underneath.
I just had a quick look and there are a few on now, but - I don't know if the pcd on the 10 series is 5 x 114.3 like mine.
Cheers!
10 hours ago, BigNev said:
Hi guys!
Cheers!
The PCD is 114.3, but the offsets are different depending on wheel size and tyre size.
