Tony X Posted September 8 Posted September 8 Hello everyone I need a new battery. My Alphard is imported from Japan. Year made 2011. I am looking to replace my battery. Can anyone suggest which model should I get from halford? Thank you !!!!
BigNev Posted September 9 Posted September 9 Hi Tony! I'd personally suggest Tayna batteries in Bodelwyddan, North Wales. They'll save you a fortune, and will send it to you next day. My car has an 027 battery fitted. I'm not saying that's right, or for yours though, it was put on by the previous owner. Cheers, Nev
MonsterS Posted September 9 Posted September 9 I second BigNev, however i always over spec the AH by at least 20 so i know it starts even when cold.
BigNev Posted September 9 Posted September 9 Hi Alex! And I agree with you! If I'm buying a battery, I try to look for the higher amp rating and "cold cranking amps" in the size. There can be quite a difference in performance for different manufacturers hey! And these cars do have a LOT of electrical kit! Just looked at Tayna, and for my reg they suggest an 068 battery. Perhaps when I'm home later I'll do some research on physical size difference to the one that's on mine. The guy I bought our car from clearly had one die shortly after he got it from the importer, and bought one local to him, as the receipt for it is in the folder! Cheers, Nev
BigNev Posted September 9 Posted September 9 So, from my tape measure, a size 068 won't fit in the battery tray on mine. And there isn't that much difference in amp grunt to the 027 option. But the one I have in it, a "Starting Bull" is at the bottom end on the range, 510 cca, whereas Varta, Bosch and Exide have 610, 610, and 640 models!! And that's without going to AGM type! They go to 680!! Cheers, Nev
Jimmympv Posted September 9 Posted September 9 Funny I was just looking for a battery myself. I've had a couple of close calls the last few weeks where it's taken a couple tries to crank. It's still got the Panasonic battery in it from Japan with the LifeWINK attached which indicates the battery health which was flashing red at me yesterday so I think it's time. The battery was fitted in 2021 thanks to previous installer writing the date on it. Gonna have to measure mine too as I'm getting conflicting info online. For example I'm reading that the Bosch S4 026 fits but when I've used part checkers on some sites it comes back as not compatible but on Tayna it comes up as a suitable option. Apparently Toyota recommend at least 550 CCA for the 3.5l so I'm just going to go with the highest CCA rating I can get my hands on with the cold season on its way. My shortlist is currently the VARTA Blue Dynamic E23, Bosch S4 026 or the Yuasa Silver YBX5068. 1
Philllx Posted Sunday at 07:36 PM Posted Sunday at 07:36 PM After a bit of research I eventually purchased for my ggh25 the Bosch S4 E41, EFB 72ah, 760cca, fits the battery tray nice, worth considering, bought from Tanya Batteries.
BigNev Posted Sunday at 08:45 PM Posted Sunday at 08:45 PM Hi Phil! I just had a look at that one, and at 261mm wide (rather than 242 for my 027 ), it could just squidge into mine. Most were 266 to 270mm. I'm reckoning if it did in yours it jolly well should do, same car model!! But - how did you go on with the retaining bracket across the top as it's 30mm higher than the 027 battery? Did it need any bending to clamp properly? Not a big deal really! The back is simple as it's the usual rod / nut with plenty of "slack" on the thread, but the front fixing is a bolt directly into the metal frame. Was it easy enough to use a longer bolt and spacer? Cheers, Nev
Philllx Posted Tuesday at 03:59 PM Posted Tuesday at 03:59 PM Hi Nev, Went straight in no modifications needed. Phil
BigNev Posted Tuesday at 09:28 PM Posted Tuesday at 09:28 PM (edited) Jolly Blooming Marvellous!!! And a monster of an output for the size! Edited Tuesday at 09:40 PM by BigNev
